I must establish a connection between two PCs via Ethernet.
I make my program using mainly SysSocket.lib, but it is at the configuration of the communication I have a problem ..
If anyone can help me ..
thanks in advance
William
Gauthey Automation France
It is much easier to use Network Variables. For this you don't have to program anything (just configuring).
In the menu Tools-Options-Features, enable Network Variables.
Add a Global Variable list to your application and set in the properties that the variables should be sent over the network.
In the application of the other device, add a Network Variable List and link this to the GVL of the other application.
Now the application will automatically send the values of the variables from one PC to the other.
It is most easy to have both applications for both devices in one project.
Anonymous
2012-06-05
Originally created by: Matthias S.
I would also prefer network variable. This is the easiest way.
As an alternative to the "raw" sockets, I can also recommend the CoDeSys CAA_NetBasedServices.lib in V3.
This lib encapsulat the socket interface. I used the TCP Server and Client Blocks in a project without problems.
By the way: what specific problems do you have?
Thanks,
Matthias
Originally created by: w71400
thanks in advance
William
Thanks,
Matthias
I would recommend using the OsCat Network Library it has been tested and validated. It also has a built in NET Var module or Modbus TCP Slave/Master.
You have to be signed in to download. This has been updated for CoDeSys V3.
http://www.oscat.de/community/index.php ... 784.0.html m
