PERSISTENT DATA
2012-01-17
2012-01-23
  • Andoni Crespo - 2012-01-17
    I have done a global persistent data list. I can reset and download keeping the persistent values but when I switch the cell off all the values are reseted. Do I have to link these values to a file o something similar to avoid losing their values when switchinf off/power failure?
    Thanks in advance
  • kberlin - 2012-01-17
    How persistent data is handled depends on the device you're programming. It can be stored directly into something like non-volatile RAM or saved to a file at powerfail.
    Which device is it that you're using?
    Best regards,
    Kristian Berlin
    Hi again
    I am using a Khunke with Windows XP Embedded.
    Thanks for your support
  • kberlin - 2012-01-23
    Is it a complete system that you bought from Kuhnke or did you install SP RTE yourself on a PC?
    Is there any nvram at all in the hardware? What does the information from Kuhnke say?
