I am using a Rasperry Pi based PLC with runtime purchased from 3S.
Now i need to configure the PLC as an Modbus RTU Serial Device.
According to the help: >Zitat:
Number of holding registers: possible values are 1β4096. The maximum number can be limited in the device description.
And sure enough it is. If I check the xml file the following is present:
Hi.
Can I just change the xml file as i want to use approx 2048 holding registers or what can be done?
