JAPIB - 2020-01-30
I'm having problems with the libraries used in the examples, from the CODESYS STORE.
For example, I installed the 'ResponsiveDesign' package. it works well.
Now I'm trying to understand how it works.
When I check the Function block 'ClientManagerListener' defined like this: FUNCTION_BLOCK ClientManagerListener IMPLEMENTS VisuElems.IClientManagerListener2
and trying to find where "VisuElems.IClientManagerListener2" is coming from, can't find the original library.
When I use the function Browse -> GoTo Definition, he points to the library "System_VisuElemBase, which contains other libraries, but I can't find what I was looking for.
Another problem is how to know the possibilities of the functions, function blocks and variables of all these undocumented libraries..
Thank you very much for your ideas.
