It is currently Mon Feb 24, 2020 9:43 pm
PostPosted: Fri Jan 17, 2020 8:45 am
I need to connect to an Epec controller with CAn interface (I have Kvaser USB-CAn adapter installed in my PC) but I cannot find the way to set can interface into communication settings..
PostPosted: Fri Jan 17, 2020 3:33 pm
Hi fleaplc, could you please share which Epec device you are using?
PostPosted: Sat Jan 18, 2020 5:41 pm
I'm using 6200 series ECU
PostPosted: Mon Jan 20, 2020 1:57 pm
You normally connect to the 6200 via Ethernet 1, not via CANbus*. Out of the box it has IP address 192.168.0.2.
See section "Getting started" -> "Going online and downloading application" of Epec Programming and Libraries Manual, and "Programming" -> "Programming 6000/X Series Units" -> "Configuration" -> "Configuring Ethernet and DNS Settings".
If it is already programmed, you can use CANmoon to connect to it.
*I think you could use also the CAN gateway, but it is slower than Ethernet: you can find instructions again in "Going online and downloading application".
Users browsing this forum: Andreas Kehrer and 12 guests
