It is currently Tue Feb 18, 2020 9:11 am
PostPosted: Thu Jan 16, 2020 4:52 pm
I have a slave drive attached to a master with MC_Phasing.
When I call SMC3_ReinitDrive is fActPosition is set to the variation of the Master position while the drive is re-initializing.
This is quite strange because it happens also if the drive's position coming from the fieldbus is constant (the axis is not moving).
I expect fActPosition not changing before and after SMC3_ReinitDrive...since the axis is not moving!
In attachment a picture of a trace what is happening...
Does anyone know what can cause such a strange behaviour?
Thank you for any kind of help!
PostPosted: Fri Jan 17, 2020 11:52 am
We found something that I hope will be useful for someone else.
The "wrong" fActPosition isn't calculated according to the encoder master's position, but it always has a variation of 216°.
This value is not causal, but it's due to the fact that the increments per output turn of the axis (in our application 65536*10 is equal to 360°) is NOT a power of two.
For our application 216°=393216 increments that is exactly the number of increments "missing" from 655360 to reach the first power of two (2^20).
(It isn't easy to imagine...but try to draw a trivial example for a 4bit encoder where you get 360° every 3 increments and it will be clear)
This is not a problem when the machine is running (it just count the increments managing the overflow I suppose)...but when you reinit the drive after a drive encoder's overflow (32bit) you get an error in fActPosition of 216° equal to 393216 increments (216°)
Now the question is...what's the best pratice to manage this problem?
I was thinking about counting the number of overflow and triggering an MC_Home after a reinit (to set fActPosition := fActPosition * 216 * numberOfOverflows)
