It is currently Mon Feb 24, 2020 8:56 pm
PostPosted: Tue Jan 14, 2020 12:41 pm
I have a CFC block which is supposed to read a value from a I2C device regularly, but before that, the device (actually an ADS1115) has to be configured once before the the evaluation of the block starts. I thought that could be done in the method FB_Init for the block. But it can't. The code compiles without any problems, but after download I get an Exception which says AccessViolation. Why? And how do I configure the device only once?
METHOD FB_Init: BOOL
VAR_INPUT
    bInitRetains: BOOL; // TRUE: the retain variables are initialized (reset warm / reset cold)
    bInCopyCode: BOOL;  // TRUE: the instance will be copied to the copy code afterward (online change)
   usiAddress : USINT:= 16#48;
   byWriteBufferC : ARRAY [0..2] OF BYTE :=[16#01,16#84,16#83]; //Sets continous mode
   write :DINT;
write:=I2C_master.write(usiAddress, ADR(byWriteBufferC),3); //Generates an AccessViolation
FB_Init:=TRUE;
PostPosted: Tue Jan 14, 2020 2:38 pm
It is a bad idea to utilize or reference any (external) objects in FB_Init other than the FB that you are initializing as you run the risk of the object (I2C_master in this case) not "existing" in memory yet when the FB is initialized.
Did you write a driver for the ADS1115? If you do, you can set the initial config of the ADS1115 using the state machine built into the template found at https://forge.codesys.com/drv/io-driver ... ?version=1
Users browsing this forum: No registered users and 8 guests
