It is currently Tue Feb 18, 2020 8:20 am
PostPosted: Thu Dec 19, 2019 12:00 pm
I am using CODESYS Control for Raspberry Pi SL 3.5.15.20
During boot codesyscontrol is executed but later it stops unexpectedly, and my codesys application will not boot.
However, I can start my application later with /etc/init.d/codesyscontrol start
I think the problem is caused by rc.local so here is the status.
What is the problem?
systemctl status rc-local.service
Warning: The unit file, source configuration file or drop-ins of rc-local.service changed on disk. Run 'systemctl daemon-reload' to reload units.
● rc-local.service - /etc/rc.local Compatibility
   Loaded: loaded (/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: enabled)
  Drop-In: /lib/systemd/system/rc-local.service.d
           └─debian.conf
           /etc/systemd/system/rc-local.service.d
           └─ttyoutput.conf
   Active: failed (Result: exit-code) since Thu 2019-02-14 11:12:16 CET; 10 months 3 days ago
     Docs: man:systemd-rc-local-generator(8)
  Process: 396 ExecStart=/etc/rc.local start (code=exited, status=2)
Feb 14 11:12:15 raspberrypi sudo[740]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/home/pi/activateCAN.sh
Feb 14 11:12:15 raspberrypi sudo[740]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 14 11:12:15 raspberrypi sudo[740]: pam_unix(sudo:session): session closed for user root
Feb 14 11:12:15 raspberrypi sudo[750]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/etc/init.d/codesyscontrol
Feb 14 11:12:15 raspberrypi sudo[750]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 14 11:12:16 raspberrypi sudo[750]: pam_unix(sudo:session): session closed for user root
Feb 14 11:12:16 raspberrypi sudo[410]: pam_unix(sudo:session): session closed for user root
Feb 14 11:12:16 raspberrypi systemd[1]: rc-local.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Feb 14 11:12:16 raspberrypi systemd[1]: rc-local.service: Failed with result 'exit-code'.
Feb 14 11:12:16 raspberrypi systemd[1]: Failed to start /etc/rc.local Compatibility.
PostPosted: Thu Dec 19, 2019 12:32 pm
Problem solved.
rc.local starts a script startPLCCAN.sh
For some reason in this script 'start' was missing for codesyscontrol. Here is the right content:
#!/bin/sh
sudo /etc/init.d/codesyscontrol stop
sudo /home/pi/activateCAN.sh
sudo /etc/init.d/codesyscontrol start
