It is currently Mon Feb 24, 2020 8:50 pm
PostPosted: Wed Dec 11, 2019 3:54 pm
I'm using the Net Base Services function blocks to communicate with LXI devices over TCP. I've successfully communicated with a Keithely DAQ6510 with no issues, but I'm having issues with a Rigol DS1054Z scope. The difference between them, as far as I can tell, is the Rigol sends a TCP Keep-Alive packet when a command will take longer to execute and the Keithley does not.
I discovered this by using a simple python script to run commands in the same way as the PLC would and used wireshark to check the TCP packets for what was going on. I can't do the same for the PLC to Rigol connection because I can't do a packet capture on those interfaces.
Is this a limitation of the Net Base Services library? Is there another way to handle the TCP Keep-Alive? I know the PLC can handle the TCP Keep-Alive because the MSSQL library I'm using is able to handle Keep-Alive packets.
I get a TCP_RECEIVE_ERROR (6012) when I try to perform a TCP_Read after the device sends the Keep-Alive.
This same function block is used both on the Keithley and Rigol devices.
FUNCTION_BLOCK LXI_Client
VAR_INPUT
   // Configuration variables
   // IP Address
   sConfigIPAddress      : STRING(20) := '192.168.10.2' ;
   // Default Port 5025
   uiConfigPort         : UINT := 5025;
   // Name to appear in logs
   sName             : STRING(20);
   // Rising Edge Triggered Reset
   xReset : BOOL;
   // Rising Edge Triggered Connect
   xConnect : BOOL;
VAR_OUTPUT
   // ID Name of Device
   sIDN : STRING(255);
   // Diagnostic Info
   sDiagnose          : STRING(80);
   // Device Busy
   xBusy : BOOL;
   // Device Connected
   xConnected : BOOL;
   // Error Flag
   xError : BOOL;
   // Error String
   sError : STRING(80);
   // High when values from query are ready in arValues
   xValuesReady : BOOL;
   // Query Values
   arValues : ARRAY[0..MAXVAL] OF REAL;
   // TCP Connection
   tcp_client             : NBS.TCP_Client := (udiTimeOut:= 5000000); // timeout in micro-seconds
   tcp_read             : NBS.TCP_Read;
   tcp_write             : NBS.TCP_Write;
   uiPort                : UINT;
   IPAddr                : NBS.IP_ADDR;
   eError                : NBS.ERROR;
   eLxiError : ENO.errno;
   bufSend : ARRAY[0..MAXBUF] OF BYTE;
   bufRecv : ARRAY[0..MAXBUF] OF BYTE;
   // Edge Trigs
   etConnect : R_TRIG;
   etReset : R_TRIG;
   // Diagnostic Information
   sOldIDN : STRING(255);
   // Helpers
   mxLxi0                : LXI_STATE;
   iPosN : INT;
   xWaitOnDevice : BOOL;
   tmrReadTimeout : TON := (PT:=T#5S);
   tmrKeepAlive : TON := (PT:=T#30S);
   // AppendConfig Vars
   posSend : INT;
   // ProcessRecv Vars
   smProcessRecv : INT;
   iVal : INT;
   sVal : STRING(20);
   iStart : INT;
   iEnd : INT;
   iRecvLen : INT;
   sRecv : STRING(255);
   // Fixed Messages
   _sIDN : STRING(6) := '*IDN?$N';
VAR CONSTANT
   MAXBUF : UINT := 1023;
   MAXVAL : UINT := 24;
etConnect(CLK:=xConnect);
etReset(CLK:=xReset);
CASE mxLxi0 OF
LXI_STATE.STOPPED:
   IPAddr.sAddr := sConfigIPAddress;
   uiPort := uiConfigPort;
   tcp_client(xEnable := FALSE);
   tcp_read(xEnable := FALSE);
   tcp_write(xExecute := FALSE);
   xBusy := FALSE;
   xConnected := FALSE;
   xError := FALSE;
   eError := tcp_client.eError;
   eLxiError := ENO.ESUCCESS;
   IF etConnect.Q THEN
      mxLxi0 := LXI_STATE.INIT;
   sDiagnose := 'not connected';
LXI_STATE.INIT:   // init client
   xBusy := TRUE;
   tcp_client(xEnable := TRUE, ipAddr := IPAddr, uiPort := uiPort);
   IF tcp_client.xBusy AND tcp_client.hConnection <> CAA.gc_hINVALID THEN
      mxLxi0 := LXI_STATE.IDN_SEND;
   ELSIF tcp_client.xError THEN
      mxLxi0 := LXI_STATE.ERROR;
   sDiagnose := 'connecting';
LXI_STATE.IDN_SEND: // ID The Device
   tcp_write(xExecute := tcp_client.xActive, hConnection := tcp_client.hConnection, szSize := sizeof(_sIDN)-1, pData := ADR(_sIDN));
   IF tcp_write.xDone THEN      // message sent, go back to idle mode
      sOldIDN := sIDN;
      mxLxi0 := LXI_STATE.IDN_RECV;
   ELSIF tcp_write.xError THEN
      tcp_client(xEnable := TRUE);
      IF NOT tcp_client.xActive AND NOT tcp_client.xError THEN   // reinit
      ELSIF tcp_read.xError THEN   // error
         eError := tcp_write.eError;
      ELSE
   sDiagnose := 'connected - sending *IDN?';
LXI_STATE.IDN_RECV:   // wait for incoming IDN
   sDiagnose := 'receiving *IDN?';
   tmrReadTimeout(IN:=TRUE);
   tcp_read(xEnable := tcp_client.xActive, hConnection := tcp_client.hConnection, szSize := SIZEOF(bufRecv), pData := ADR(bufRecv));
         eError := tcp_read.eError;
      ELSE
   IF tcp_read.xReady THEN
      mxLxi0 := LXI_STATE.WAIT_FOR_MESSAGE;
      tmrReadTimeout(IN:=FALSE);
      iPosN := OB.BUFFER_SEARCH(ADR(bufRecv),UINT_TO_INT(SIZEOF(bufRecv)), '$N', 0, FALSE);
      sIDN := OB.BUFFER_TO_STRING(ADR(bufRecv),SIZEOF(bufRecv), 0, INT_TO_UINT(iPosN - 1));
   IF tmrReadTimeout.Q THEN
      eLxiError := ENO.ETIMEDOUT;
LXI_STATE.WAIT_FOR_MESSAGE: // idle mode - wait for message in queue to send
   xBusy := FALSE;
   xConnected := TRUE;
   sDiagnose := 'waiting for messages';
   // Use IDN query as keep alive - connection checking
   tmrKeepAlive(IN:=TRUE);
   IF tmrKeepAlive.Q THEN
      tmrKeepAlive(IN:=FALSE);
      xBusy := TRUE;
LXI_STATE.SEND_MESSAGE:
   xBusy := TRUE;
   tcp_write(xExecute := tcp_client.xActive, hConnection := tcp_client.hConnection, szSize := INT_TO_UDINT(SIZEOF(BYTE) * MAX(1, posSend)), pData := ADR(bufSend));
      IF IsQuery(ADR(bufSend), SIZEOF(bufSend)) THEN
         mxLxi0 := LXI_STATE.WAIT_FOR_RESPONSE;
      ELSE
      OB._BUFFER_CLEAR(ADR(bufSend), SIZEOF(bufSend));
      posSend := 0;
      ELSE
   sDiagnose := 'sending message';
LXI_STATE.WAIT_FOR_RESPONSE:
   sDiagnose := 'receiving';
   IF xWaitOnDevice THEN
      tmrReadTimeout(PT:=T#60S);
   ELSE
      tmrReadTimeout(PT:=T#5S);
   OB._BUFFER_CLEAR(ADR(bufRecv), SIZEOF(bufRecv));
      ELSE
      xWaitOnDevice := FALSE;
      // writeRead will set state to wait for message
      mxLxi0 := LXI_STATE.PROCESS_RESPONSE;
LXI_STATE.PROCESS_RESPONSE:
   ProcessRecv();
   mxLxi0 := LXI_STATE.ACK_RESPONSE;
LXI_STATE.ACK_RESPONSE:
   IF NOT xValuesReady THEN
LXI_STATE.ERROR:
   xError := TRUE;
   xConnected := TRUE;
   sDiagnose := 'Error ';
   sDiagnose := CONCAT(sDiagnose, INT_TO_STRING(eError));
   sDiagnose := CONCAT(sDiagnose, ' LxiError:');
   sDiagnose := CONCAT(sDiagnose, INT_TO_STRING(eLxiError));
END_CASE
OB._BUFFER_INSERT(CONCAT(sName, ': '), 0, ADR(sDiagnose), SIZEOF(sDiagnose));
IF xError THEN
   sError := sDiagnose;
ELSE
   sError := '';
IF etReset.Q THEN
   posSend := 0;
   mxLxi0 := LXI_STATE.STOPPED;
PostPosted: Thu Dec 12, 2019 4:34 pm
Could it be due too "sizeof(_sIDN)-1" ?
I would expect the sizeof result to be 6, so you would not pass $n at the end of the string to the write block as you should.
EDIT : telling this because if the write is busy, then read will go on error.
Also when you come from WAIT_FOR_RESPONSE, I don't see call for tcp_read with execute false.
PostPosted: Fri Dec 13, 2019 5:43 pm
sizefof(_sIDN) returns the length of the string + the null terminating byte. Sending the null byte causes errors on the scope and prevents any sort of query response. That's why the -1.
Good call on the missing tcp_read(xEnable := FALSE); Maybe that is blocking the tcp stack from handling the keep-alive. Not an issue on the other device which doesn't send the keep alive, but could be the issue here.
I'll test that out.
PostPosted: Fri Dec 13, 2019 9:51 pm
dFx: That was the issue. Added the tcp_read(xEnable := FALSE); after completing the read and the keep-alive works.
Users browsing this forum: No registered users and 8 guests
