It is currently Tue Feb 18, 2020 7:21 am
PostPosted: Tue Nov 26, 2019 3:26 pm
I want to diagnose status of IEC tasks via code using "cmpIecTask" library.
For Example I want to use "IecTaskGetFirst" with the interface:
Return - IecTaskGetFirst --- RTS_IEC_HANDLE - Returns the handle to the first IEC task
Input - pszAppName ----- POINTER TO STRING - Application name
--------- pResult ------------ POINTER TO RTS_IEC_RESULT - Pointer that returns the runtime system error code
My problem is the input "pszAppName".
If I put manually the name of the application in te input everything work fine but I want to create a library than I need to readout the "Application Name" directly from the code. :(
Someone know how to read the "Application Name" via IEC-code?
Thanks!!!!
PostPosted: Tue Nov 26, 2019 5:06 pm
Hi.
Maybe this helps:
CmpApp library, function AppGetProjectInformation.
This function return not only project info, but app info too.
Make CODESYS great again
PostPosted: Fri Jan 03, 2020 8:33 am
You can do something like this:
char appName[96];
RTS_HANDLE pInterface;
pInterface = CAL_IecVarAccGetFirstInterface(NULL);
while (pInterface != RTS_INVALID_HANDLE)
CAL_IecVarAccGetApplicationName(pInterface, &appName[0], sizeof(appName);
pInterface = CAL_IecVarAccGetNextInterface(pInterface, NULL);
Users browsing this forum: Andreas Kehrer and 5 guests
