Hi, I am using Linux as my OS
And I want to get the 'Bus cycle task name' of codesys application,
so that I can set the task to a specific cpu core to enhance my throughput
I know users can select bus cycle task or can change the task names using IDE
But how to get the current name of the bus cycle task? is there a function call can do this?
Thank you
Thank you~ I surveyed this lib once
I saw many attributes of a task in 'Task_Info2'
But I didn't find any symbol related to 'Bus cycle task'
I want to know which task in my application is the 'bus cycle task' bounded by user
Can you give me some clues?
Appreciated
To me (I may be wrong), you are looking for some bus/device/variable property that would define the associated refresh task.
Try to have a look while online (even simulating), to visualize the structures associated to your bus device.
can't help that much.
To return the name, Task_Info2.pszName^ string to return it.
You provided a good direction to check
I was looking around components about 'Task properties' with no luck before
Bus/device items may have the answer to my question, I'll try to find it out
Thanks, please notice me if you have any other idea
Thank you
https://help.codesys.com/webapp/IecTaskGetInfo3;product=CmpIecTask;version=3.5.14.0
Appreciated
