  <TypeSimplename="T_MODESMARCHE_ENUM"size="1"swapsize="1"typeclass="Enum"iecname="MODESMARCHE_ENUM"/>  <TypeUserDefname="T_CsgModeFct_STRUCT"size="24"nativesize="24"typeclass="Userdef"iecname="CsgModeFct_STRUCT">   <UserDefElementtype="T_REAL"iecname="DebitAir"byteoffset="0"/>   <UserDefElementtype="T_REAL"iecname="DebitAirTol"byteoffset="4"/>   <UserDefElementtype="T_REAL"iecname="Temp"byteoffset="8"/>   <UserDefElementtype="T_REAL"iecname="TempTol"byteoffset="12"/>   <UserDefElementtype="T_REAL"iecname="Hygro"byteoffset="16"/>   <UserDefElementtype="T_REAL"iecname="HygroTol"byteoffset="20"/>  </TypeUserDef>  <TypeArrayname="T_ARRAY__0__3__OF_CsgModeFct_STRUCT"size="96"nativesize="96"typeclass="Array"iecname="ARRAY [0..3] OF CsgModeFct_STRUCT"basetype="T_CsgModeFct_STRUCT">   <ArrayDimminrange="0"maxrange="3"/>  </TypeArray>  <TypeUserDefname="T_Consignes_STRUCT"size="100"nativesize="100"typeclass="Userdef"iecname="Consignes_STRUCT">   <UserDefElementtype="T_ARRAY__0__3__OF_CsgModeFct_STRUCT"iecname="Mode"byteoffset="0"/>   <UserDefElementtype="T_TIME"iecname="TempsPoly"byteoffset="96"/>  </TypeUserDef>    <Nodename="Consignes"type="T_Consignes_STRUCT"access="Read">   <Comment>Consignes</Comment>  </Node>
  {attribute'symbol':='read'}  Consignes:Consignes_STRUCT;    TYPEConsignes_STRUCT:STRUCT  Mode:ARRAY[ModeFct_ENUM.HorsGel..ModeFct_ENUM.Poly]OFCsgModeFct_STRUCT;  TempsPoly:TIME;END_STRUCTEND_TYPE Â
as of somachine 4.3, OPC UA does not correctly shows items which are in an array declared with enum bounds. It shows only first index members.
Is this ok with later versions of codesys ?
Can you provide an example of an array declared with enum bounds?
Effect seen in opc ua bowser
application.xml
OpcUASymbolConf.map
Declaration in codesys
