It is currently Mon Jan 27, 2020 3:37 am
PostPosted: Thu Jan 09, 2020 8:22 am
Hello, we have a Topocon Electronics (ex Wachendorff Elektronik) panel that runs Codesys 3.5.14.0.
We bought a Codesys Key to deploy a license, since these panels seem not have a softcontainer, but when trying to use License Manager (Device -> Dongle) Codesys says no adapter is available.
Furthermore, when deploying the DeviceReader project/example, it shows no green lights under Single License (neither dongle nor softcontainer), even if the dongle is connected via USB and recognized as a USB HID device by the OS (which is Linux, a Yocto build, BTW).
Is there anything we could try?
PostPosted: Fri Jan 10, 2020 6:30 pm
could you please check if CmpCodemeter is available in the plc logger after the startup of the runtime.
If so, you could switch the key to a mem device ( not HID) and mount it and use it that way. ( how to switch the key from HID you'll find
in the online help of Codemeter)
HID ( prefered use) need ยท CONFIG_HID CONFIG_HIDRAW in the Linux kernel.
Cheers
PostPosted: Sun Jan 12, 2020 12:58 pm
Thank you.
Yes, CmpCodeMeter is in the log, and the kernel has CONFIG_HID set (to module) but CONFIG_HIDRAW is not set.
Tomorrow I will try reconfiguring as a mass storage (seems to be a piece of cake).
PostPosted: Mon Jan 13, 2020 8:13 am
Unfortunately, issuing
cmu32 -s <serialno> --set-config-disk RemovableDevice
(or LocalDevice, for what is worth) in the CodeMeter Command Prompt as per https://www.wibu.com/support/faq/detail ... emory.html does not work: it tells to unplug and replug the key, but when replugging it is still recognized as HID from Windows.
PostPosted: Mon Jan 13, 2020 7:08 pm
try:
cmu32 /s [Serialno] --set-config-disk MsdCommunication
http://localhost:22352/$help/CmUserHelp ... to_msd.htm
PostPosted: Tue Jan 14, 2020 4:15 pm
Thank you! The device now appears, but every time I try to deploy it a license (EtherCAT master SL) through the device, Codesys runtime crashes almost immediately with
terminate called after throwing an instance of 'std::out_of_range'
  what():  basic_string::replace
and on the PC a dialog box appears saying "Communication error: 0x1cc", then "Transfer of license information from device failed" (obvious, the runtime crashed...)
On another device hardware, same Codesys version (3.5.14.0) but a more recent software environment, the error is
  what():  basic_string::replace: __pos (which is 4294967295) > this->size() (which is 12)
PostPosted: Thu Jan 16, 2020 5:27 am
Plug the Key to the CODESYS pc and activate the licence with your browser -> license.codesys.com
After activation plug it to the plc...mount it...then it should work
Cheers
PostPosted: Thu Jan 16, 2020 5:00 pm
Ok, finally worked.
Thank you for your help!
