It is currently Fri Feb 21, 2020 7:09 pm
PostPosted: Wed Oct 09, 2019 9:17 am
I have set up Modbus TCP Client in Codesys 3.5.12 to read/write to are remote IO and I want to be able to change the IP of a Modbus TCP server (slave) in Codesys if the IP of the remote IO changes.
The change of the slave IP should be made through a HMI or WebVisu.
Modbus TCP slave has a method called UpdateCommunicationSettings with IP and Port as parameters.
It says that "Fails (return value !=0) if TCP connection is currently established. (-->Use Enable Property to connect/abort)".
Where do I find this Enable property?
PostPosted: Wed Oct 09, 2019 9:01 pm
You can find it in the online help
https://help.codesys.com/webapp/_mod_li ... ion_editor
Modbus TCP slave instance name .xEnable
PostPosted: Thu Oct 10, 2019 6:12 pm
The problem is tha I can't see xEnable property in the inputs and outputs list of the FB at all.
My Modbus TCP Slave name is IO_Board and I get an error when I type IO_Board.xEnable.
------ Build started: Application: Device.Application -------
typify code ...
[ERROR] FB_CoolingUnit: FAULTS_CHECKING [Device: PLC Logic: Application](Line 15, Column 1 (Impl)): C0018: 'IO_Board.xEnable' is no valid assignment target
[ERROR] FB_CoolingUnit: FAULTS_CHECKING [Device: PLC Logic: Application](Line 15, Column 1 (Impl)): C0004: 'xEnable' is no component of 'MODBUSTCPSLAVE'
Compile complete -- 2 errors, 0 warnings
PostPosted: Thu Oct 10, 2019 7:24 pm
So in order for the Enable property to be shown, the option "EnableDiagnosis for devices" in PLC Settings has to be activated.
PostPosted: Thu Oct 10, 2019 7:46 pm
Great! So is it all working now?
PostPosted: Fri Oct 11, 2019 10:54 am
Yes.
Thanks for the tips.
