It is currently Tue Mar 19, 2019 8:12 pm
PostPosted: Mon Apr 16, 2018 10:30 am
Hi!
I want to pass a array of strings throught a function and that function is going to return back the array. So I need to use pointers for that.
Let's keep it simple!
I first have my array:
myStrArray: ARRAY[0..10] OF STRING;
Then I need to convert myStrArray to a pointer.
p_myStrArray: POINTER := ADR(myStrArray);
Then I need to pass p_myStrArray throught my function
p_returnArray := myFunc(p_myStrArray);
FUNCTION myFunc: POINTER
VAR_INPUT
   p_myStrArray: POINTER;
END_VAR
VAR
END_VAR
myFunc := p_myStrArray; // Return statement
And then recive my pointer and turn it back to an array
returnArray: ARRAY[0..10] OF STRING;
returnArray := p_returnArray^;
But it won't work for me. What have I missed?
PostPosted: Mon Apr 16, 2018 11:53 am
Wrap your array with an fb and pass the fb to the funtion as varinout. Or better, the funtion could be an method of the fb.
If not, you don t know from inside the funtion array dimension.
PostPosted: Mon Apr 16, 2018 5:08 pm
I didn't know the compiler would allow this
VAR_INPUT
END_VAR
Maybe try this instead
FUNCTION myFunc: POINTER  ARRAY[0..10] OF STRING
VAR_INPUT
   p_myStrArray: POINTER  ARRAY[0..10] OF STRING;
END_VAR[/quote]
Then when you call the function you may try this
VAR
    MyStrArray: ARRAY[0..10] OF STRING;
    PtrReturnArray : POINTER TO ARRAY[0..10] OF STRING;
END_VAR
PtrReturnArray := myFunc(ADR(MyStrArray));
