It is currently Sat Feb 22, 2020 2:18 am
PostPosted: Thu Apr 25, 2019 9:15 am
I'm struggling. I'm more of an occasional CoDeSys user rather than a professional.
What I am trying to do is to read serial characters and append them to a string. When I read a character from the input object, it is an ASCII value (g = 103 etc.) So I need to convert that value to the character "g" and then concat it to the string.
I've spent ages Googling and not found an answer so I thought I'd ask here.
Any suggestions very welcome.
Thanks in advance,
Richard
PostPosted: Thu Apr 25, 2019 5:38 pm
I propose a function :
FUNCTION F_ASCII_TO_STRING : STRING(1)
VAR_INPUT
InputVal: UINT;
Caracter:STRING(1);
CASE InputVal OF
48:Caracter:='0';
49:Caracter:='1';
50:Caracter:='2';
51:Caracter:='3';
52:Caracter:='4';
53:Caracter:='5';
54:Caracter:='6';
55:Caracter:='7';
56:Caracter:='8';
57:Caracter:='9';
65:Caracter:='A';
66:Caracter:='B';
67:Caracter:='C';
68:Caracter:='D';
69:Caracter:='E';
70:Caracter:='F';
71:Caracter:='G';
72:Caracter:='H';
73:Caracter:='I';
74:Caracter:='J';
75:Caracter:='K';
76:Caracter:='L';
77:Caracter:='M';
78:Caracter:='N';
79:Caracter:='O';
80:Caracter:='P';
81:Caracter:='Q';
82:Caracter:='R';
83:Caracter:='S';
84:Caracter:='T';
85:Caracter:='U';
86:Caracter:='V';
87:Caracter:='W';
88:Caracter:='X';
89:Caracter:='Y';
90:Caracter:='Z';
97:Caracter:='a';
98:Caracter:='b';
99:Caracter:='c';
100:Caracter:='d';
101:Caracter:='e';
102:Caracter:='f';
103:Caracter:='g';
104:Caracter:='h';
105:Caracter:='i';
106:Caracter:='j';
107:Caracter:='k';
108:Caracter:='l';
109:Caracter:='m';
110:Caracter:='n';
111:Caracter:='o';
112:Caracter:='p';
113:Caracter:='q';
114:Caracter:='r';
115:Caracter:='s';
116:Caracter:='t';
117:Caracter:='u';
118:Caracter:='v';
119:Caracter:='w';
120:Caracter:='x';
121:Caracter:='y';
122:Caracter:='z';
ELSE
Caracter:='';
END_CASE;
F_ASCII_TO_STRING:=Caracter;
How to use it ?
PROGRAM PLC_PRG
ValNum:UINT;
Result:STRING;
Result:=F_ASCII_TO_STRING(ValNum);
Hoping this will meet your needs :D
PostPosted: Thu Apr 25, 2019 5:50 pm
May not be the best solution but what you could do is:
    sTempString : STRING;
    pConvertString : POINTER TO BYTE;
    bySerialByte : BYTE;
//First get the address of the temporary string to store your character
pConvertString := ADR(sTempString);
//Second assign the decimal value to the temporary string
pConvertString^ := bySerialByte;
//Third "sTempString" now equals the ascii character and you can concat it to something else
    //Add your code to concat to another string example: sOriginalString := CONCAT(sOriginalString, sTempString);
You could put this in a function or OSCAT might already have a function to do something like this.
PostPosted: Thu Apr 25, 2019 8:01 pm
why you are using workarounds, when the util Lib does, what you are searching for 8)
After conversion do the concat...
PostPosted: Thu Apr 25, 2019 9:34 pm
Is that library available with that function in Codesys version 2.3 where this question was posted? I don't know what libraries are available in 2.3 since I don't use it is why I ask. My answer was a way to accomplish it without caring about what library is available in 2.3.
PostPosted: Fri Apr 26, 2019 9:31 pm
For D.Kugler
This library shown in the post is available with CODESYS V3.5. :oops:
The library Util available with CoDeSys V2 don't offer this function. :D The only conversion functions are BCD functions (INT_TO_BCD, BCD_TO_INT).
For Cmingback4u :
Your solution is simpler and more elegant than mine. :D
PostPosted: Sat Apr 27, 2019 10:17 am
Sorry i'm thinking and working most in V3.5 and only sometimes in V2.3! Forget my post or use it in V3 :D
