It is currently Sat Feb 22, 2020 1:14 am
 Post subject: Variable Type detection?
PostPosted: Sat Feb 16, 2019 8:11 pm
Can CoDeSys do conditional variable type identification?
Example:
I have a scale function that takes in a REAL value and scales it to some new range, then outputs a REAL. But, sometimes I’m trying to scale an INT, or a DINT, or a BYTE or SINT, etc. how can I make this function automatically recognize the input type, do a xxx_TO_REAL, run my scale function, then do a REAL_TO_xxx, then output the result as an xxx instead of a REAL?
Any solution besides “make a different function for each variable type” would be awesome.
Thanks!
PostPosted: Wed Feb 20, 2019 4:10 pm
In this case I would use; INT_TO_REAL(your_var) or WORD_TO_REAL(your_var) etc.
PostPosted: Thu Feb 21, 2019 4:19 am
Codesys V3 now supports the ANY_TYPE, which would work, but I don’t believe this is available on Codesys V2.3.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Tue Nov 05, 2019 7:40 pm
So, it works this way for using different inputs. That's good.
But, I also want it to output into the same type as whatever is connected.
Is this possible? (Example: I'd like to modify this function to work regardless if dd is a REAL, INT, BYTE, ...)
FUNCTION anyTestFunction : REAL
VAR_INPUT
in1: REAL := ANY_TO_REAL(in1);
in2: REAL := ANY_TO_REAL(in2);
in3: REAL := ANY_TO_REAL(in3);
anyTestFunction := in1 + in2 + in3;
PROGRAM PLC_PRG
aa: INT := 2;
bb: REAL := 2.1;
cc: BYTE := 3;
dd: REAL;
dd := anyTestFunction(aa, bb, cc);
PostPosted: Tue Nov 12, 2019 1:50 am
You could return the ANY type, but then you would have to determine which type within the ANY type.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Tue Nov 26, 2019 11:37 am
i do it by paralleling inputs and outputs in ver 2 so input is real and int same as output.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
