It is currently Wed Jan 29, 2020 9:27 am
PostPosted: Thu Mar 15, 2018 11:44 am
Greetings.
I have an PFC200 PLC from WAGO (750-8208), which has a RS232 / RS485 port on the front.
I would like to use that port to communicate with an external device using a custom RS485 protocol (i.e. not modbus rtu). I have implemented using the SysLibCom library and tested the protocol code using the simulator. I cannot get the communication to work when connecting the PLC to the device, or even to my laptop via a FTDI RS485 dongle. I suspect that something is not right in the com port setup on the PLC.
Maybe I'm missing something obvious, but I can't see a way to tell SysLibCom that COM0 should be treated as an RS485 port and not a RS232. Can anyone tell me how to do this? Is it even necessary?
My code looks like this:
PROGRAM PT100_PRG
   sComSettings: COMSETTINGS;
   ePort : PORTS := COM0;
   bIsConfigured: BOOL := FALSE;
   bIsOpen: BOOL := FALSE;
   dwHandle: DWORD;
   dwErrorCount : DWORD := 0;
VAR CONSTANT
   bAddress : BYTE := 0;
   dwErrorHandle : DWORD := 16#FFFFFFFF;
(* implementation starts here *)
IF bIsOpen = FALSE THEN
   bIsConfigured := FALSE;
   dwHandle := SysComOpen(ePort);
   IF dwHandle <> dwErrorHandle THEN
      bIsOpen := TRUE;
IF bIsOpen = TRUE AND bIsConfigured = FALSE THEN
   sComSettings.byParity := 0;
   sComSettings.byStopBits := 0;
   sComSettings.dwBaudRate := 38400;
   sComSettings.dwTimeout := 0;
   sComSettings.dwBufferSize := 0;
   sComSettings.dwScan := 0;
   IF SysComSetSettings(dwHandle, ADR(sComSettings)) = TRUE THEN
      bIsConfigured := TRUE;
(* ... and some write logic here *)
Thanks in advance.
/Mikkel
PostPosted: Tue Apr 03, 2018 8:04 pm
Are you sure that it's COM0 not COM1?
PostPosted: Tue Apr 03, 2018 8:33 pm
It is typically a hardware setup, not on the coding side. On some controllers, it is a BIOS setting. Perhaps it is a configuration selection however you setup the hardware (WAGO specific).
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Wed May 09, 2018 1:09 pm
Thanks for the inputs. With the help of WAGO support, I found the solution which I'm posting here for future reference.
When using the RS232/RS485 port on the PFC200 module, make sure to:
  • Use Serial_Interface_01.lib from the PFC200 library folder
  • Use COM0
  • Set flowcontrol to half-duplex for RS485
What tripped me, was using the "wrong" library, not that it was documented anywhere that I could find.
/Mikkel
