It is currently Wed Jan 29, 2020 5:34 am
 Post subject: Array questions
PostPosted: Tue Feb 20, 2018 4:07 pm
Dear all,
1.is it possible to declare an array, with a size taken from initializer.
In C it is:
int a[]={1,2,3}
How I do the same in codesys?
Please note, I DON'T request run-time dynamic array. I only request to don't declare a size abut take it from amount of initializers, like in C.
2. How array are passed in function blocks?
Var input
invar array [0..5] of int;
end var
What is passed only the "reference" or the copy of the whole array on the stack. If so, how do I only pass array by reference? I want to read from array inside of the block, but don't want to write something back.
Note: Pointers are not allowed in my company.
Thanks a lot!
 Post subject: Re: Array questions
PostPosted: Thu Feb 22, 2018 3:43 am
An answer to your second question:
There are two solutions for passing an array reference without passing the whole array while not using pointers:
  • Use VAR_IN_OUT - this forces the inclusion of the variable on every call and uses by reference behind the scenes. The downside is if you really just want a var input, you could adjust the value inside the FB without problems and create bugs.
  • Use the keyword REFERENCE TO when you define your variable. It will pass the variable by reference and you can use it for VAR_INPUT, VAR_OUTPUT, and VAR. I put an example below. Be aware you should still check for validity of the reference in case it has never been set! Hint - if you only use REFERENCE TO in Method VAR_INPUTS, the programmer must assign it, so you don’t have to check validity!
VAR_INPUT
   History : REFERENCE TO ARRAY[0..99] OF DWORD;
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Fri Feb 23, 2018 10:47 am
Thanks a lot, Scott!
I would like ask Codesys (if they read) to implement Const References for that and also implement my 1. point in ST.
PostPosted: Tue Apr 03, 2018 8:07 pm
Why??? :shock:
Users browsing this forum: No registered users and 9 guests
