It is currently Fri Jan 24, 2020 7:27 pm
PostPosted: Tue Oct 17, 2017 1:14 pm
I am used to functions returning only one data type, depending on how the function itself is declared (for example FUNCTION fName : INT, which returns an INT).
However, I read the follwoing at Beckhoff's webpage in their chapter about functions
"According to the IEC 61131-3 standard, functions can have additional outputs. Those must be assigned in the call of the function, for example in ST according to syntax:
out1 => <output variable 1> | out2 => <output variable 2> | ...further output variables"
[1]
I am familiar with this in Function Blocks where you declare your output variables for example inside a VAR_OUTPUT (...) END_VAR, but I am hoping that someone could show me an example of additional outputs in a Function?
[1]: https://infosys.beckhoff.com/english.php?content=../content/1033/tc3_plc_intro/27021597900156043.html&id=
PostPosted: Thu Oct 19, 2017 1:51 am
Define the outputs the same way as a function block. You can keep the traditional single output and and the second and third and fourth outputs as var outputs or you can delete the traditional output type and put all outputs as var outs.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Wed Nov 01, 2017 6:06 pm
Trying to add VAR_OUTPUT in a function results in compiler error 3820: " 'VAR_OUTPUT' and 'VAR_IN_OUT' not allowed in functions"
The code I tried looked as follow
Declaration:
(* Declaration *)
FUNCTION F_fun : BOOL
VAR_INPUT
   bIn1 : BOOL;
   bIn2 : BOOL;
END_VAR
VAR_OUTPUT
   bOut1 : BOOL;
   bOut2 : BOOL;
END_VAR
VAR
END_VAR
(* Code *)
bOut1 := bIn1;
bOut2 := NOT bIn2;
PostPosted: Wed Nov 01, 2017 9:06 pm
Looks like it's a limitation with the version you are running. In version 3, it works. A crude workaround would be to create your function as a program instead and define any local variables as VAR_TEMP so they reset at every call.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Mon Nov 06, 2017 9:45 am
The link refers to Version 3 Twincat, Here it works, however in 2.3 it is not working, you should have 1 output var returned by a function, however it is still possible to change other outputs within a function.
It all depends on the type of machine and software.
and yes you are correct, please use FB for this.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
