It is currently Thu Jan 23, 2020 12:16 am
PostPosted: Fri Jul 28, 2017 12:38 pm
Im upgrading a HVAC control system, i found a decent macro but the macro is for liquid heat battery, and this application has electrical.
I would like to use the % output from the valve controller to trigger the heat elemets. Total heat is 110kw (2 x 7kW + 1x14kW + 1x27kW + 1x55kW)
All 5 heat elemets ar triggered by DO, what function could i use to calculate wich outputs at a given time will give the most correct DO to activate?
Example:
0% = 0kW
25% = 27kW (only 27kW aktice)
50% = 55kW (Only 55kW active)
75% = 82kW (Only 55kW + 27kW) active
100% = 110kW (all active)
PostPosted: Tue Aug 15, 2017 4:25 pm
A late answer, but here is a basic FB that will do it (assumes your command is 0 to 100):
FUNCTION_BLOCK HeatControl
VAR_INPUT
   CmdSignal : INT := 0;
VAR_OUTPUT
   Heat7KwA : BOOL := FALSE;
   Heat7KwB : BOOL := FALSE;
   Heat14Kw : BOOL := FALSE;
   Heat27Kw : BOOL := FALSE;
   Heat55Kw : BOOL := FALSE;
0% = 0kW
//turn all off first
Heat7KwA := FALSE;
Heat7KwB := FALSE;
Heat14Kw := FALSE;
Heat27Kw := FALSE;
Heat55Kw := FALSE;
//now see which should be on
IF CmdSignal >= 100 THEN
   Heat7KwA := TRUE;
   Heat7KwB := TRUE;
   Heat14Kw := TRUE;
   Heat27Kw := TRUE;
   Heat55Kw := TRUE;
ELSIF CmdSignal >= 75 THEN
   Heat27Kw := TRUE;
   Heat55Kw := TRUE;
ELSIF CmdSignal >= 50 THEN
   Heat55Kw := TRUE;
ELSIF CmdSignal >= 25 THEN
   Heat27Kw := TRUE;
ELSE
   ; //none
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Thu Aug 24, 2017 7:43 am
Thanks for your reply.
Im sorry if my question wasn't crystal clear.
I would like a function that calculate all the time and then find the nearest combination to match the requested input.
Is there any pre-made function for this?
PostPosted: Sat Aug 26, 2017 4:59 pm
That is what my function block will do based on your information. Call it every scan with your input and it will turn on or off whatever heaters you need.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Fri Sep 15, 2017 6:17 pm
This is the solution i came up with, in case someone else need this.
This function calculates the remaining kW wich are given by Heat7KwA with TRIAC.
VAR_INPUT
VAR_OUTPUT
  Triacscaled: INT := 0;
   Triac : INT := 0;
Triacscaled := (CmdSignal - Triac) * 100 / 7;
IF CmdSignal >= 103 THEN
   Heat7KwB := TRUE;
   Heat14Kw := TRUE;
   Heat27Kw := TRUE;
   Heat55Kw := TRUE;
   Triac := 103;
ELSIF CmdSignal >= 96 THEN
   Heat14Kw := TRUE;
   Heat27Kw := TRUE;
   Heat55Kw := TRUE;
   Triac := 96;
ELSIF CmdSignal >= 89 THEN
   Heat7KwB := TRUE;
   Heat27Kw := TRUE;
   Heat55Kw := TRUE;
   Triac := 89;
ELSIF CmdSignal >= 82 THEN
   Heat27Kw := TRUE;
   Heat55Kw := TRUE;
   Triac := 82;
ELSIF CmdSignal >= 76 THEN
   Heat7KwB := TRUE;
   Heat14Kw := TRUE;
   Heat55Kw := TRUE;
   Triac := 76;
ELSIF CmdSignal >= 69 THEN
   Heat14Kw := TRUE;
   Heat55Kw := TRUE;
   Triac := 69;
ELSIF CmdSignal >= 62 THEN
   Heat7KwB := TRUE;
   Heat55Kw := TRUE;
   Triac := 62;
ELSIF CmdSignal >= 55 THEN
   Heat55Kw := TRUE;
   Triac := 55;
ELSIF CmdSignal >= 48 THEN
   Heat7KwB := TRUE;
   Heat14Kw := TRUE;
   Heat27Kw := TRUE;
   Triac := 48;
ELSIF CmdSignal >= 41 THEN
   Heat14Kw := TRUE;
   Heat27Kw := TRUE;
   Triac := 41;
ELSIF CmdSignal >= 34 THEN
   Heat7KwB := TRUE;
   Heat27Kw := TRUE;
   Triac := 34;
ELSIF CmdSignal >= 27 THEN
   Heat27Kw := TRUE;
   Triac := 27;
ELSIF CmdSignal >= 21 THEN
   Heat7KwB := TRUE;
   Heat14Kw := TRUE;
   Triac := 21;
ELSIF CmdSignal >= 14 THEN
   Heat14Kw := TRUE;
   Triac := 14;
ELSIF CmdSignal >= 7 THEN
   Heat7KwB := TRUE;
   Triac := 7;
