It is currently Fri Jan 24, 2020 5:36 pm
PostPosted: Tue Jun 13, 2017 2:22 pm
Hi all.
So I am having this strange problem, where I need specific number of digits in my counter. I need the counter to be able to count up to 9999999, but the number of digits always has to be the same. This means, when the counter starts it should be 0000001, then later on it will be 0001021 and so on.
I would prefer to convert the counter into string later on, so maybe there is a solution there? I am completely out of ideas on how to easily realize this.
Please help ;)
Best regards,
PostPosted: Fri Jun 16, 2017 1:43 pm
First, make sure your counter supports the high number (you need a dword output). Then you Use DWORD_TO_STRING to get the number as a string. Also define a string '0000000'. Concat the two together and then your answer is MID(togetherstring, LEN(togetherstring)-7,7). Or about that
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Mon Jun 26, 2017 1:15 pm
I actually made it happen like this, because I am not familiar with repeat of while funcitons as yet :)
STRINGcounter:=DWORD_TO_STRING(DWORDcounter);
IF LEN(STRINGcounter)=1 THEN
   TEMPcounter:=CONCAT('0', STRINGcounter);
   TEMPcounter:=CONCAT('0', TEMPcounter);
ELSIF LEN(STRINGcounter)=2 THEN
ELSIF LEN(STRINGcounter)=7 THEN
   TEMPcounter:=STRINGcounter;
I am not proud of it but it works ;)
PostPosted: Mon Nov 06, 2017 9:57 am
have a look at www.oscat.de for a nice library containing all sorts of manipulation, and yes you may be proud of your solution.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
