It is currently Fri Jan 24, 2020 5:45 pm
 Post subject: Start contact
PostPosted: Wed May 24, 2017 3:29 pm
Good morning,
I would have a question for you:
Is there a way to have a conception that opens and then closes when the program starts on the plc?
In my project I have 4 OSCAT timers that at a certain time perform an operation only that every time the application loads on the plc the timers leave.
I would like to create a denied contact that at startup interrupts the timer output to say 5 seconds and then closes.
it's possible ?
Thank you, Alberto
 Post subject: Re: Start contact
PostPosted: Sun Sep 24, 2017 1:32 pm
I see you never received an answer. Hopefully you solved this. Otherwise my idea:
Define another timer for 5 seconds and call it all the time.
   BootDone : TON;
 BootDone(IN:=TRUE, PT:=T#5S);
 IF BootDone.Q THEN
    //ok to use other timer values now
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
