It is currently Sat Jan 25, 2020 4:22 am
PostPosted: Sat Feb 18, 2017 12:28 pm
Hello
I have made a program that works, but it don't work as an Function block.
It takes the input from VAR1_1 og ekstern and takes tha last value and send it to VAR_ut.
I'm going to use it on a modbusdevice. So you can set the setpoint on the local device and from a remote panel.
ROGRAM ModbusRW
VAR
(*Variabler for objekt nr. 1*)
   VAR1: REAL;
   VAR1_1: REAL;
   VAR1_OLD: REAL;
   VAR1_1_OLD: REAL;
   Count1: REAL;
   ekstern: REAL;
   VAR_ut: REAL;
END_VAR
   (*Les inn data fra Modbus*)
   (*VAR1_1 kobles mot rett variabel i modbus lese blokk etter kovertering til rett datatype*)
   (*VAR1_1 må deklareres som global variabel*)
   (*Sjekker om dette er første scan etter strømstans*)
   (*Hvis det er første scan hentes data fra modbus og legges inn i ekstern variabel*)
   IF Count1 < 1 THEN
      VAR1 := VAR1_1;
      ekstern(*ekstern variabel*) := VAR1;
      VAR1_OLD := VAR1;
      VAR1_1_OLD := VAR1_1;
      Count1 := 1;
   END_IF;
   (*Leser opp ny verdi hvis verdi endrer seg på modbus*)
   IF VAR1_1 <> VAR1_1_OLD THEN
      VAR1 := VAR1_1;
      VAR1_OLD := VAR1;
   END_IF;
   (*henter ekstern variabel*)
   VAR1 := ekstern(*ekstern variabel*);
   IF VAR1 <> VAR1_OLD THEN
      (*PRG navn*);
      VAR1_OLD := VAR1;
      VAR_ut := VAR1;
   END_IF;
When I try to make it as an function block it don't work. Can sombody help me understand way?
VAR_INPUT
   ekstern: REAL;   (*eksterinput*)
   VAR1_1: REAL;   (*modbus input*)
END_VAR
VAR_OUTPUT
   VAR_ut: REAL;
END_VAR
VAR
   VAR1: REAL;
   VAR1_OLD: REAL;
   VAR1_1_OLD: REAL;
   Count1: REAL;
END_VAR
   IF Count1 < 1 THEN
      VAR1 := VAR1_1;
      VAR1_OLD := VAR1;
      Count1 := 1;
   END_IF;
      VAR1 := VAR1_1;
      VAR1_OLD := VAR1;
   END_IF;
      (*PRG navn*);
      VAR1_OLD := VAR1;
      VAR_ut := VAR1;
   END_IF;
Thanks
Espen
PostPosted: Sun Feb 19, 2017 12:08 pm
a function block does not save any variables, so if you need to keep any values , you will have to use in/out variables with external vars (global)
so your count is always 0 for example.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Sun Feb 19, 2017 1:56 pm
Function blocks keep loca variable memory - counter will work. Functions do not - counter will not work. VAR_IN_OUT type are for situations where the variable is both an input and output ("I need it and I may also change it).
Make sure you are calling the Function block instance every PLC scan.
This is not calling the B - it only changes the variable: myFB.ekstern := 5.3;
This calls the FB and runs it: myFB();
Also, VAR_INPUTs cannot be changed from the inside - if you change ekstern in your FB, it does not change the variable you mapped to it. In the FB you change the VAR_INPUTs, but the next call, they will be back to your old values (VAR_INPUT means "I give you this value and you cannot change it"). Programming recommendations suggest never modifying VAR_INPUTs inside the POU.
Try your program again using the variables as defined in the FB (programs can also have VAR_INPUTS VAR_OUTPUTS too). I don't think it will work and you should find your problem.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Fri Feb 24, 2017 7:32 am
Thank you for your help. I made a PRG and used that.
