It is currently Sat Jan 25, 2020 3:06 am
 Post subject: Convert TIME to REAL
PostPosted: Sat Feb 04, 2017 11:57 am
I need to calculate step value for some time period like this:
bStep=(targetLevel-currentLevel)/(timePeriod/t#10ms)
targetLevel,currLevel,bStep - REAL
timePeriod - TIME
my TON1 has PT:=t#10ms and when TON1.Q I need to add bStep to bValue
Now I have Type mismatch in division so I think I need to convert TIME to REAL, or TIME to INT and INT to REAL
Is it possible?
Best Regards
Marek
 Post subject: Re: Convert TIME to REAL
PostPosted: Sat Feb 04, 2017 1:05 pm
Sorry newbie question ;)
Conversion Operator TIME_TO_REAL
Best Regards
Marek
PostPosted: Sat Feb 04, 2017 9:45 pm
because the scantime is a problem, check if you can get the needed precision.
maybe you need the clocktime to get enough accuracy of the step.
another way to get correct results, is by adding the step/time in a way like an x/y line can be computed.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Mon Feb 13, 2017 10:58 am
You can make use of the SysTime library, get the starting time in st1 and the stop time in st2, then calculate the elapsed time inbetween. It can be within a cycle or several cycles later, it doesn't matter.
VAR
    st1, st2: SysTime;
    diElapsedTimeUs: DINT;
END_VAR
//Get starting time (in us)
SysTimeGetUs(pUsTime:=st1);
//Do something
//Get stop time (in us)
SysTimeGetUs(pUsTime:=st2);
//Calculate elapsed time (in us)
diElapsedTimeUs:=ANY_TO_DINT(st2-st1);
