It is currently Wed Jan 22, 2020 11:37 pm
 Post subject: array
PostPosted: Fri Dec 16, 2016 5:09 pm
how can i delete tags in a array.
array [1 to 64]:words.
I only need the tags from [1..4] but not tag [5],[6] /11 12 /17 18 etc...
only first 4 words (word 5 en 6 not needed also to some for 11 12 etc until 64)
here a example put not correct programmed like it must be...
arraynew[1]:=arrayold[1]
arraynew[2]:=arrayold[2]
arraynew[3]:=arrayold[3]
arraynew[4]:=arrayold[4]
arraynew[5]:=arrayold[7]
arraynew[6]:=arrayold[8]
arraynew[7]:=arrayold[9]
arraynew[8]:=arrayold[10]
 Post subject: Re: array
PostPosted: Sun Dec 18, 2016 2:50 pm
If you want to use ARRAY type, then you need to manually shift data yourself like:
Data[0] := Data[0];
Data[1] := Data[1];
Data[5] := Data[7];
Data[6] := Data[8];
It may be possible of course to use variables with a skip routine instead of hard coding...
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Mon Dec 26, 2016 10:19 pm
well stijn the program you made should work, (did you declare both arrays correct in the varaiable list?
what errors do you see?
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
