It is currently Sat Jan 25, 2020 3:10 am
PostPosted: Tue Jun 21, 2016 10:44 am
I'm programming a quadricopter and in the visualization windows I insert the position I need to reach.
This values are assigned to some specific variables which are used in the FB.
How can I dinamically assigned those to some other in the FB?
I need to do that because the other variables are also used in the Plant.
Thanks.
PostPosted: Wed Jun 22, 2016 11:27 am
a locally defined var is in every instance of a function block has another name. maybe you will need to use a in/out var.
btw this question belongs in V3 .
I also hope codesys is fast enough to control your copter as a PLC tends to be too slow for these type of fast operating things.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Tue Jun 28, 2016 3:22 pm
Hi, there's my problem.
I need to dinamically modify the inputs of a FB by using values which are given as input in a visualization window.
Then I need to assing those values to another variables that are the outputs of the same FB.
There's a way to do that?
PostPosted: Tue Jun 28, 2016 7:22 pm
in a function block there are inputs outputs and in/outputs possible.
that way you can keep setting values or integrator from the out back to the in.
please give sample project as export file and what do you need. as i am not sure what the question is.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
