It is currently Thu Jan 23, 2020 12:31 am
PostPosted: Fri Jun 03, 2016 11:06 am
At work I have a lot of projects that are made with an older version of CodeSys Version 2.3.7.1.
I've searched for an old version repository so I can install the same CoDeSys version as was used by these project, but I can't find it anywhere. Can someone tell me where I can find the installer for CodeSys Version 2.3.7.1?
PostPosted: Sun Jun 05, 2016 8:27 pm
yep, however it is not likely to be codesys, but probably wago or alike, please more info on used system. like target
and it should be possible to change the compiler.
I normally put all project (including IDE on a stick.and into the project map.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Mon Jun 06, 2016 9:10 am
found AMK in kirchheim unter teck.
and yes they do have their own line of controllers and hardware.
It is pretty normal, the old gets obsolete, however it is codesys aipex pro, so the base is indeed codesys, however it has its own additions, like motion. I have no idea if it is plcopen.org compliant (dutch based organization, zaltbommel).
They do have their own line of servo elektronics, so yes it maybe is visible, however to find the orioginal compiler would be to ask the AMK yourself.
And yes it is possible to assist you with changes etc.
(you will need to have the original PRO and the correct compiler along with all libraries etc.
So it is not very simple to do, however the original programmer has to have all these files.
shooter@home.nl
computer shooter
paul deelen
phone +31736139136
