Is it possibile to plot X-Y trend in CODESYS?
lukebarber
2016-01-10
2016-01-13
  • lukebarber - 2016-01-10
    X is position of axis 1 and Y is position of axis 2.
  • shooter - 2016-01-11
    yes that is possible, however it means a lot of memory has to be used for array, if possible use vectorpoints, it saves on memory, and it is faster.
    It is depending of the precision needed.
    i used a vector array, and the points were connected with a polygonline.
    on the graph i had put 100 points all on same place (with a texteditor, and i can change the relative points with the software.
  • lukebarber - 2016-01-13
    Hi Paul,
    Thanks a lot for your response.
  • shooter - 2016-01-13
    if needed more info, please give more info.
