i have problem to configure the hardware with CoDeSys 3.0 SP. In the Hardware side i want to use FC3102 PCI card from Beckhoff as master and CDD3000 from Lust Antriebstechnik GmbH as slave. First problem is that i cannot get gsd file for FC310x PCI card to make it master so i tried for other gsd file available on internet since the parameter are same for mater then i tried to read gsd file for CD3000 which is available from company website but when i load it using Add Object function its gives error message "REFERENCE OBJECT IS NOT SET TO INSTANT OF OBJECT" And i am unable to configer the hardware to new CoDeSys 3.0 SP
I will be greatfull if someone help me out if possible with some tutorial as i am new for using CoDeSys:
MUSSAB
2007-05-14
Originally created by: Bernhard Reiterer
Dear Mussad
As far as i know, no driver is currently available for the FC3102 that is usable with CoDeSys 3.x. If there is, you should get a separate device description file (.devdesc.xml) along with the gsd file, which you should use instead of the gsd file directly.
I had a look at the CDD3000 GSD file. IMHO it uses a construct not completely compliant to the GSD specification and which causes pain to CoDeSys:
ExtUserPrmData   =1"..."Prm_Text_Ref    =1Bit(7)        00-1EndExtUserPrmData
From my understanding of the specification, the line```
Bit (7)...
``` should be the first line after
So, if you move the line in before the [Prm_Text_Ref] line it works fine in CoDeSys (there is also a second ExtUserPrmData section which must be changed accordingly):
ExtUserPrmData   =1"..."Bit(7)        00-1Prm_Text_Ref    =1EndExtUserPrmData
Don't forget to reimport the gsd file after your changes.
Hope that helps,
Bernhard
Thank you for your reply but i have still some problems in communication. As you said CoDeSys 3 does not have driver for FC3102. So now i try CoDeSys SP RTE 2.3 .This version has a driver for FC3102 and PLC Configration tag i am able to add FC310x as master and LUST CDD3000 as slave . I also modified GSD file as you suggest . Now it does not have previous error. But when i try to login "Communication Error; Logout Performed" error come. I read help to get out from this error but fail to produce result. Can you help me you again? I also want to ask you what will be the parameter for Communication Parameter tab since PCI card is connected to the Local PC. Does i need to use Gateway server?
Thanks in advance
mussab
2007-06-05
Originally created by: Frank Hailer
Hi Mussab
I hope you performed the following steps before you tried to download the program:
configuration of the FC310x driver and the RTE (description in the document 'CoDeSys SP RTE_E.pdf' which is part of the RTE installation)
starting RTE (inclusive 'Start System')
setting valid communication settings in CoDeSys (Online -> Communication parameters...), exemplary > Gateway - Local < and > Device - Shared memory (Kernel) <
After that the download should work.
Best regards, Frank
Hi everyone,
MUSSAB
Dear Mussad
Bit (7)...
Hope that helps,
Bernhard
Dear Bernhard
Thanks in advance
mussab
Hi Mussab
Best regards, Frank
