I would like to know if it is possible to compile a program and upload it to the PLC via batch command line?
The idea is to be able to switch from different versions automatically.
Regards
```The problem is I can't get it to log in silently. The query and replace commands don't seem to help at all, even though I do remember them working a year ago. Anyway, you should probably read these two entries in the help file yourself, if you haven't done it yet:
Regards
Bump.
It should be something along the lines of```
"C:\Program Files (x86)\3S Software\CoDeSys V2.3\Codesys.exe" /batch /cmd build_and_run.cds file.pro
build_and_run.cds
project build
online login
online run
Thank you very much!
Regards
