i am new with programming so i'm asking maybe stupid questions, so if i have analog input what gives value from 400 to 1000. Value 400 is for example 80 cm and 1000 is 1100cm. How i can make a program which tells automatically how many cm is value 500?Hope somebody understand this...
thanks
2015-09-16
This is a linear equation of style y = ax + b. I will leave you to fill in the blanks on the equation details.
So create a FUNCTION - but you first need to decide your data type. INT or REAL... You are using nice rounded numbers, so I will pick INT (using ST language):
Hello!
thanks
Then in your regular program you can simply write:
HINT: Always make sure you don't overflow the data type! INT only goes to +32767.
