MODBUS
thaisjx
2015-06-18
2015-06-22
  • thaisjx - 2015-06-18
    Hi there,
    I'm using a MODBUS configuration in CODESYS between a WAGO 758-874/000-131 and a WAGO 750-872.
    The project compiles with no errors but I can't write in the OUTPUTs of my slave (WAGO 750-872). I only can read its inputs.
    Maybe is there any library missing? Could anybody help me?
    Thank you very much!
  • shooter - 2015-06-18
    what addresses are you using on the slave, and what is the configurstion.
    you will need to add an offset for correct addresses.
  • thaisjx - 2015-06-22
    The problem was that my outputs were configured in PI allocation as 'PLC, PLC' not as 'Modbus TCP/UDP'. But now it works.
    Anyway thank you for your answer. Have a nice day.
