communication error(#0): logout performed
bezzaouia
2015-05-27
2015-05-29
  • bezzaouia - 2015-05-27
    Hi, i'm trying to connect Turck BL20-PG-EN using CoDeSys V2.3 the communication parameters are correct but when i try to login I get the message "communication error(#0): logout performed". so can someone help me with steps to perform a login and to download my project.
    thank you
  • shooter - 2015-05-29
    what port is used on the PC and do you have the target set correct, there is under online a communications parameterset.
    and the settings in the turck should be checked with a special program available from website.
