How to tell which library is causing change-notification when I open a project?
Running 2.3.9.37 on two different computers.
CoDeSys reports differences in libraires when compiled on one, and opened on hte other.
So, easy right? I just have to have a mismatch in target or something right?
But its not so easy
I have checked EVERY file including the target-directory in:
C:\Program Files (x86)\3S Software\CoDeSys V2.3\ (This includes the Target)
Checking was done using a SourceTree application (Mecurial), and also by just comparing a 'DIR /S' dump's - NO files are different except:
\CoDeSys.ini (And this is just which project was opened last etc).
ALL other files are identical including all library files.
I have some libraires in sub-folders of the project, but these are referenced relatively by '.\lib' so they are also the same.
Any suggestions?
When i make a system i copy all files (and libs on a stick and put it in the manual.
2015-02-11
Originally created by: Nicolai_Hanssing
Well thats the thing - everything is identical - even the file-dates.
That I have checked with "CompareIt" on the output of DIR /S of the Target, Project and CodeSys directories...
If I compile on a computer with the change-notification, then it can just go online, so apparently the resulting binarycode is completely identical.....
even if you save the pro file it sees, a change, so first save the file (it is a option before compiling)
and keep it away from any change. That is only way to be sure.
as soon as the * is seen on the filename, it can go wrong.
(same for the libs)
But its not so easy
Any suggestions?
they must be fully identical even the datestamp.
(same for the libs)
