It is currently Sun Jan 19, 2020 11:01 am
 Post subject: CoDeSys and C5-PCC (KEB)
PostPosted: Thu Aug 25, 2005 1:52 pm
Connection KEB C5-PCC (Programmable Communication Controller) with the CoDeSys via the Ethernet interface produced with the next settings:
Online -> Communication Parameters...
Address: 192.168.0.95 (IP of the C5)
Port: 1200
Block Size: 512
Motorola Byteorder: Yes
At the attempt to make connection with C5-controller CoDeSys writes in window "Messages": "0 Error(s), 0 Warning(s)". But at that time gives out the message "Communication Error (#0): Logout Performed". All adjustments are taken from Users Manual of C5-PCC, IP of the unit is also true... Please help us to solve this problem.
 Post subject:
PostPosted: Tue Aug 30, 2005 10:27 am
If I were you first of all I check connection PC<->PLC with ping. If connection is OK then make sure that CoDeSys runtime system is executed.
 Post subject:
PostPosted: Tue Sep 06, 2005 6:27 am
Thanks. Now is Ok. It was necessary to establish additional components and libraries С5... I'm an idiot :roll:
