so you are looking for this particular block
i found in the eaton moeller standard lib.
another place for this is w www.oscat.de w with lots of functions also this type (it is english. download the codesys lib the pdf file and the txt file to study.
use OSCAT library..using the CLK_PRG FB you can generate a pulse (one shot) clock based on a defined time base, then you can create your square wave "manually"..
this is a sample with T#500ms time base
PulseGen500ms:CLK_PRG;
( Pulse one shot 500ms )
PulseGen500ms(PT:=t#500ms , Q=>_500ms );
( Clock 500ms )
IF _500ms THEN
Clock500ms:=NOT Clock500ms;
END_IF;
Dear all, IΒ΄m programming an 750-880 WAGO, and I need a function block to generate time periods, can you send me the library for the FB.?
I'm not sure if i'm getting it right, but is'nt this what you looking for?
/Niclas
Well I would like to download the function block.
/Niclas
( Clock 500ms )
IF _500ms THEN
END_IF;
