I'm glad I found this forum on the internet. I'm building the prototype of a new machine in our house in Phoenix, AZ, USA. The machine will utilize a new LM 3108 PLC from China and a Weintek 6050i HMI. The HMI uses Easybuilder. The PLC uses CoDeSys. I've been successful programming the HMI with touch screens, but writing programs in CoDeSys with the PLC software manual has been a struggle. I know the HMI will operate as the master, and the PLC as the slave in MODBUS RTU. I'm sure I can write the PLC program with enough self-study. But for now, I don't know how to integrate the HMI program into the LD program for the PLC.
I'm still trying some things. The problem is: to establish communication between the HMI and the PLC. I've built the assembly in the photo, so I can write short programs to turn the motor on and off. I've been reading the software manuals for the PLC and the HMI for the past few months. It would be a big success to start the motor by touching a button on the touch screen of the HMI.
Attached are screen shots of the Codesys program and the HMI program. I know I haven't entered some of the necessary data in the Codesys Program. I'm still studying the software.
aha i saw your elance but did not react on it.
i see %QX0.0 that should be coil_1
where is the motor_on FB in the POU list.
there should be a POU called PLC_PRG
i see VAR CONSTANT
but all u use should be under
here your list like Coil_1
give the function block another name as the program itself.
start with simpler one
add POU
it will start with PLC_PRG
set the type on ladder
startbutton at %MX0.0 :BOOL; ( this is address 40000 )
input1 AT %IX0.0 :BOOL; ( this is an input on the PLC, if active the output should go on when everything is correct )
output1 AT %QX0.0 :BOOL; ( this is your coil )
program
startbutton as a contact
make a extra input and OR it with your startbutton
OR input1
and output1 as the coil
go online
it will ask to download the program
go to start
now program is running
make input1 active.
and yes you can PM me
e shooter@home.nl e however i like it via this forum so others can see what is happening and learn from it.
Thanks very much for your help. I'm in the middle of the process of collaborating with an experienced programmer in India. We're using teamviewer. I sent your information to him.
sent the program by exporting it to me and i will have a look, please make lots of comments in your program so i can see what you like to have.
if flowsheet available please
and what should the unclear picture do?
use markers (%M0.1) etc.
you can ask them in your HMI.
Here is the Codesys screen shot.
Codesys is easy to program so u can tell roughly what sort of sequence you are looking for?
Trust me try ST,FB and SFC instead of Ladder logic you will succeed fast
Thanks. I've found a programmer who is helping me online at Elance.com.
i see VAR CONSTANT
add POU
program
OR input1
go online
go to start
make input1 active.
It's okay. I'm working online with the other programmer on Elance. He is very experienced, and I'm sure we'll succeed.
