It is currently Sun Jan 19, 2020 12:07 pm
PostPosted: Mon Apr 04, 2005 5:32 pm
Sorry, I am not sure that this is an appropriate forum for that kind of questions.
I have the tnf-file containing the following (our target ID value replaced with XXXXX).
[Targets]
Target1=fwio.trg,XXXXX
[Files]
In order to run the InstallTarget silently, I issue the following command from the bat-file:
"%CDSDIR%"\InstallTarget.exe d:\work\fwio\tsp\fwio.tnf /auto "%CDSDIR%\Targets\Fastwel"
where %CDSDIR% is an environment variable pointing to installtarget.exe location. The fwio.trg is located in d:\work\fwio\tsp\.
But this command doesn't install our target ("%CDSDIR%\Targets\Fastwel" remains empty).
Could anyone please suggest the correct way to silently run the InstallTarget utility (in particular, from installshield script)?
Thanks in advance.
Alexander Lokotkov
PostPosted: Wed Apr 06, 2005 10:58 am
To use enviroment variables you need the InstallTarget.exe with version 1.1.0.0. It is part of the CoDeSys V2.3.4.1 setup.
The options of InstallTarget are:
<Path InstallTarget-exe> "<Path Info-file *.tnf>" /auto [<install directory>]
If you want to use it in a Batch-File, this works:
"%CDSDIR%\InstallTarget.exe" d:\work\fwio\tsp\fwio.tnf /auto %CDSDIR%\Targets\Fastwel
(note the missing quotation marks)
If you want to use it in an InstallShield script, this works:
szCommand = '"' + TARGETDIR ^ 'InstallTarget.exe"';
szCmdLine = '"' + szTNFFile + '" /auto ' + szInstallDir;
if (LaunchAppAndWait (szCommand, szCmdLine, WAIT) < 0) then
MessageBox(@ERROR_INSTALLTARGET, SEVERE);
endif;
I hope that helps,
Sabine Mack
 Post subject:
PostPosted: Wed Apr 06, 2005 11:24 am
Thanks for your help. It works perfectly.
