read/write to XLS file
Easy rider
2011-05-26
2015-03-11
  • Easy rider - 2011-05-26
    I am working on a little project where Codysys is running on a notebook for now, the notebook needs to be connected to a Wago 750-881 controller later on.
    Now I managed to write an value (UDINT) to a database.xls file in the same directory as the *.pro file. Now I would like to read a value (UDINT,STRING) and so on into codesys.
    Actually the ideal situation would be that I would like to plug a USB stick into the notebook and read/write the *.xls file from there, but than I have to put in somewhere a path to the file from codesys and I can find that option.
    Can someone put me in the right direction?
  • proto - 2015-03-10
    G/Day
    I have the same problem. Can somebody help?
    Thanks a lot
  • shooter - 2015-03-11
    or use the library with file from the wago website
    or use oscat.de library.
