Robkristiaan is correct but if you are trying to change an upper bound "globally" like inside functions you build in a library ect... You can use a global constant like:
VAR_GLOBAL CONSTANT
MAX_ALARM_INDEX :INT := 24;
then you can change it in one place in the global variables and use it like:
MyArray :ARRAY[0..MAX_ALARM_INDEX] OF INT;
Make sure you select (Check box) in the PROJECT-OPTIONS-BUILD menu "Replace Constants" other wise you will get a compile error.
This is the closest to getting a dynamic array allocation by replacing with a constant.
Hello everybody,
it's possible to create an array dynamically?
I need to create something like this:
FUNCTION_BLOCK example
VAR_INPUT
VAR_OUTPUT
UpperBound :=_UpperBound;
PROGRAM MAIN
x := 3;
ex(_UpperBound := x);
Does someone can help me ?
Thanks for you help by advance.
It is not possible to create a dynamic array,
CoDeSys allocates the memory at build time not at runtime.
VAR_GLOBAL CONSTANT
