It is currently Sat Jan 25, 2020 2:37 am
PostPosted: Wed Mar 01, 2006 6:36 pm
Is there a library that offers the ability to send a character string out through the host computer's serial port?
Jason
 Post subject:
PostPosted: Thu Mar 16, 2006 11:01 am
What about SysLibCom?
It allows to open/close serial ports, and to read/write data from/to them.
Or are you looking for something different?
Arie N. Verheul
 Post subject:
PostPosted: Wed Mar 22, 2006 10:28 pm
I thought that was what I should use, but I can't seem to interpret the examples that I have found online. Can anyone post some working POU's with SysLibCom?
Jason
 Post subject:
PostPosted: Thu Mar 23, 2006 2:54 pm
Jason,
I've done quite some RS232 interfacing between CoDeSys controlled PLC and other equipment.
Basically I've one task handling one serial port, with one 'low-level' POU (FB) handling basic RS232 actions (sending requests and receiving responses) and a 'higher-level' POU (PRG) determining which subsequent requests to send based on received responses.
The higher level POU is continuously calling (polling) the low-level POU, checking it's status to determine if the low-level POU has finished transmitting the current request, or has finished reading the expected response etc.
The low-level POU is a state machine with several (job)states and several (job)results, and it's only this POU that uses the functions from SysLibCom
Some extra states are needed because the low-level POU is only sending a certain amount of bytes at a time, and also is reading a certain amount of bytes at a time, before handing over control to the higher-level POU (so that eventually also other tasks can get a chance to run).
States:
JOB_IDLE: (* Do nothing *)
JOB_SEND_REQUEST: (* Send request *)
JOB_SEND_REQUEST_CONTINUE: (* Send more bytes from (large)request *);
JOB_WAIT_FOR_ANSWER (* Wait for response *)
JOB_WAIT_FOR_ANSWER_CONTINUE (* Wait for more bytes from (large)response *)
JOB_PROCESS_ANSWER (* Process response *)
JOB_RETRY (* Send request again *)
Results:
STATE_READY
STATE_BUSY
STATE_TIMEOUT
STATE_WRONG_ANSWER
STATE_TRANSMIT_ERROR
STATE_INIT
STATE_NOT_USED
Arie N. Verheul
 Post subject:
PostPosted: Thu Mar 23, 2006 8:10 pm
That sounds like a good idea, similar to what I would like to set up.
I have tried using syslibcom.lib, but can't get even the SysComOpen function to work. My plc is configured with the target system being a PCI card with an integrated PLC installed inside my computer. This card does not have any serial ports, and I am hoping to use the host PC's RS 232 port, not a port on the target card.
I have duplicated the code from this post on the German board:
http://forum.3s-software.com/viewtopic. ... hlight=232
but it cannot successfully open COM2.
Is this possible?
 Post subject:
PostPosted: Mon Oct 06, 2008 1:15 pm
anverheul : Is it possible to have a copy of the source?
Best regards,
Frank
PostPosted: Tue Sep 27, 2016 12:49 pm
bump: any updates to this? :)
PostPosted: Fri Sep 30, 2016 7:59 pm
check the codesys site
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
cron
