It is currently Sat Mar 25, 2017 10:34 am
PostPosted: Fri Oct 10, 2008 3:09 pm
Hi to all you techies.
I'm using EASY215 with CoDeSys.I tried the Traffic light example but had some problems.Can anyone provide me with step by step guide to do programming.Any useful docs will be a great help.Currently I'm in need of a simple program to blink a LED with the press of a button.
You can even give me sample programs or tell me as to where shall I get them.
Thanks in advance.
 Post subject:
PostPosted: Mon Oct 13, 2008 4:37 am
It's easy to just toggle blinking of e.g. a led. Try this code in your project.
PROGRAM PLC_PRG
   Button1 AT %IX0.0   : BOOL;          (* A button connected to first digital (binary) input *)
   Led1 AT %QX0.0      : BOOL;          (* A led connected to first digital (binary) output *)
   Blink1              : BLINK;         (* Make an instance of Blink FB. Found in Utils.lib *)
   Trig1               : R_TRIG;        (* Rising edge detection. Found in Standard.lib *)
   xBlink              : BOOL := FALSE; (* TRUE=Blinking enabled, FALSE=Blinking disabled *)
Trig1(CLK:=Button1);
IF Trig1.Q THEN                         (* If detected a rising edge *)
   xBlink := NOT xBlink;                (* Toggle blink state *)
        IF NOT xBlink THEN
          Blink1(ENABLE:=FALSE);        (* Reset blink routine *)
          Led1 := FALSE;                (* and output. Doing a OUT=>Led1 does not guarantee to switch led off *)
IF xBlink THEN
   Blink1(ENABLE:=TRUE, TIMELOW:=t#500ms, TIMEHIGH:=t#500ms, OUT=>Led1);
Regards,
Frank Thaule
 Post subject: Thanks
PostPosted: Mon Oct 13, 2008 2:02 pm
Hey Buddy...Thanks a lot for the program.It ran successfully.Can you give me some more progs on fbd.
Thanks in advance.
 Post subject:
PostPosted: Tue Oct 14, 2008 10:44 am
Do you mean example routines built using function block diagram technique? Any particular operation in mind? By the way, I would strongly suggest searching for examples. There is a lot of them in this forum, alternatively google.
Regards,
Frank Thaule
 Post subject:
PostPosted: Tue Oct 14, 2008 11:50 am
Yeah I want simple FBD routines.I'm learning fbd so that i'm finally able to implement openCAN on easy215 PLC chip.So can you help me with this objective in mind?Well ST programs would also be fine..
Take Care.
