It is currently Mon Feb 27, 2017 5:23 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Thu Feb 23, 2006 8:31 am
Hi All,
I am wondering if anybody has a sample program for recipe control. We need to select and manage up to 100 recipes each with 100 words/variables. I am new to CoDeSys programming and appreciate your help.
Any ideas are welcomed.
Rob
 Post subject:
PostPosted: Fri Feb 24, 2006 9:11 pm
I have not done one in CoDeSys but in general, recipe systems involve arrays. Structured Text seems to be the easiest language to accomplish this.
First you need a place to store the recipe information:
awMyRecipeArray: ARRAY [1..100,1..100] OF WORD;
Then you need a place to hold the current (active) recipe and the number of the current recipe
iCurrentRecipe: INT;
iSelectRecipe: INT;
awCurrentRecipe: ARRAY [1..100] OF WORD;
Finally you need code to move the current recipe back into the main storage array (in case it changed) and also to move the new recipe from the main storage area into the current area. Something like this....
if iSelectRecipe <> iCurrentRecipe then
   for i := 1 to 100 do
      awMyRecipeArray[iCurrentRecipe,i] := awCurrentRecipe[i];
      awCurrentRecipe[i] := awMyRecipeArray[iSelectRecipe,i];
   end_for;
   (* Update the Current Recipe number so it doesn't get loaded again *)
   iCurrentRecipe := iSelectRecipe;
end_if;
nOrM
nOrM = Norman Dziedzic Jr.
 Post subject:
PostPosted: Mon Feb 27, 2006 12:53 pm
Thanks Mate. With a few mods, this done the job well. Stay tuned for more questions as we blunder our way through codesys.
Also, this is on an ABB PLC so many new adventures ahead.
Thanks,
Rob.
 Post subject:
PostPosted: Wed Mar 01, 2006 2:40 am
I have the following suggestion assuming that your recipe are stored in memory some where. I like to reference structures so that you can give the variables of the recipes descriptive names. I also believe it's faster than for loops by passing pointers. I included the project so you can play with it. But here is the jist of the code.
Create a structure
TYPE RECIPE :
STRUCT
   wPorportional      :WORD;
   wIntergral         :WORD;
   wDerivative      :WORD;
   wScale         :WORD;
   wOffset         :WORD;
END_STRUCT
END_TYPE
Create some variables in your program:
   bNewRecipe         : BOOL;               (* When triggered causes a memory read *)
   dwSelection         :DWORD;               (* Selection of which recipe, visualization limits it from 0 to 3 *)
   dwOffset            :DWORD   := 16#A;      (* Offset since there are 5 words = 10 bytes = 16#A to move between each recipe*)
   tCurrentRecipe      :RECIPE;               (* Currently stored recipe *)
   tRecipeMemory      :POINTER TO RECIPE   := 16#82DCA0;   (* Base address of first recipe in memory *)
   tTempRecipe         :POINTER TO RECIPE;   (* Used as a temporary variable *)
Now change the contents of the structure each time the button is pressed and the index changes. Hope you get the idea.
IF bNewRecipe THEN
   (* Move the address to the temp recipe *)
   tTempRecipe   := tRecipeMemory + (dwSelection * dwOffset);
   (* Store the contents of the memory into the current recipe *)
   tCurrentRecipe   := tTempRecipe^;
(* Now you can reference variable like this in your code*)
(*   tCurrentRecipe.wDerivative
   tCurrentRecipe.wIntergral
   tCurrentRecipe.wOffset
   tCurrentRecipe.wPorportional
   tCurrentRecipe.wScale*)
That's it on an operator display as the user presses an arrow or something to scroll through the recipes he changes the index and selects accept. That was easy!!
Thanks,
Steve Pfeifenroth
 Post subject:
PostPosted: Wed Mar 01, 2006 2:43 am
Some how the file didn't get uploaded. Dummy me again no .pro allowed!!!
Thanks,
Steve Pfeifenroth
 Post subject:
PostPosted: Tue Jan 20, 2009 7:38 pm
What I dont't understand in this program is how do you know the base address (82DCA0), is it a byte address like %MB100 ?
I work with Moeller XC201 MIPS III
Gildas THOMAS
 Post subject:
PostPosted: Tue Jan 20, 2009 7:59 pm
Your PLC of choice will have some way of accessing memory. Whether it is by using addressing like in my example, a FB provided by your PLC vendor or something. The example was trying to reflect that you can read the contents of memory and store them in a consistent interface that makes it not only easy to read but can also have data that has varying variable sizes and it still works. The pressing of buttons only skips to the next structure in memory. I do not know the Moeller PLC but I would have to ask you the question how do you store retained data? Is it by R/W files (Windows CE)? Directly in some EEPROM/FLASH? If you have a FB that reads and writes to memory if you want to post a project with the FB I can give you back an example with your particular PLC vendor. Once you have the method of retrieving stored data you can apply the principals in this example. Let me know if you need further help.
Thanks,
Steve Pfeifenroth
 Post subject:
PostPosted: Mon Jan 26, 2009 3:38 pm
isn't the CoDeSys instruction ADR whitch can do that ?
It doesn't seem to work...
Gildas
 Post subject:
PostPosted: Mon Jan 26, 2009 6:07 pm
The ADR operator is for returning the pointer to a CoDeSys variable in memory. Can you use it to access Memory that CoDeSys is unaware of I'm not sure. I am not sure what your confusion is? You said you used the ADR operator but to do what? What are you trying to accomplish? If you can help me understand your situation I may be of better help.
Thanks,
Steve Pfeifenroth
 Post subject:
PostPosted: Mon Jan 26, 2009 6:31 pm
The pointer to memory address 16#82DCA0 was just an arbitrary number it didn't mean anything. I guess I could have just used 0 as well. Recipes are normally stored in some type of non-volatile memory. You can change my example around to make it match your situation. I have assumed here that the structures are stored together in memory.Take for instance I have a manufacturer specific FB to read and write to FRAM memory on my PLC. I give it a starting address in bytes from 0 and the length in bytes to read it will return the bytes using the ADR operator. By knowing this initial offset in memory I know know where all the Recipes are stored because I know the size of the structure. It will work for RAM memory as well. So each time a user requests a different recipe I call FRAM_READ with the base address plus the users offset of which recipe and the number of bytes to read, the FB will pass it back into the structure.
Thanks,
Steve Pfeifenroth
PostPosted: Wed May 23, 2012 10:54 am
Maybe an old converstion but....
You said
Quote:
"By knowing this initial offset in memory I know know where all the Recipes are stored because I know the size of the structure."
. My question: Is there an list of used adresses in RAM in Codesys that you have an review of adresses, else how do you know where to set the adress and if it is already used by system?
regards
PostPosted: Wed May 23, 2012 5:42 pm
I'm not really sure of your question? Can you explain further? If I define a structure of structures or in this case:
TYPE RECIPES :
STRUCT
  RECIPE1 :RECIPE;
  RECIPE2 :RECIPE;
  RECIPE3 :RECIPE;
  RECIPE4 :RECIPE;
  RECIPE5 :RECIPE;
END_STRUCT
END_TYPE
RETAIN
    MyRecipes :RECIPES;        (* Define it as retain memory*)
OR
MyRecipes AT%MW0 :RECIPES;                                                          (* Define it as a memory address *)
OR
MyRecipes :RECIPES;        (* Define it in RAM *)
OR
FRAM_READ (NumBytes := 50, StartAdr := 101, DST := ADR(MyRecipes )); (* Read it from some custom specific PLC memory location *)
wSelected_Index :word := 0; (* Zero based to reach the first structure *)
wRecipeOffset  := 10; (* 5words * 2 = 10 bytes *)
dwRecipeIndex     := ADR(MyRecipes ) + (wRecipeOffset  * Selected_Index);
CurrentRecipe      := dwRecipeIndex^;  (* Deference the currently selected structure *)
Does this help?
Thanks,
Steve Pfeifenroth
PostPosted: Mon Jun 11, 2012 3:35 am
Though it is a basic question I would like to know what is the use of offset here?Is it just for 100 bytes memory for each recipe
PostPosted: Mon Jun 11, 2012 3:24 pm
I think you miss typed? You stated 100 but it is 10? It is the number of bytes that each structure holds based on the data types that are in the structures. You are referring to my comment 5 words * 2 bytes = 10 bytes?
Thanks,
Steve Pfeifenroth
Users browsing this forum: A. Akkerman and 4 guests
