CoDeSys 2.3 Gateway troubble after installing IndraWorks 13V12
GunnarK
2016-12-19
2023-08-17
  • GunnarK - 2016-12-19
    Hello.
    When I download my project from CoDeSys 2.3 to the PLC during loggin I also download a symbol file.
    After i Installed Bosch Rexroth IndraWorks 13V12 I had problem with the gateway. The symbol file and the Default.PRG file is not downloaded. I get the Error message "The last online service has not been executed correctly! Service Number: 48, Error number: 80, File Default.PRG could not be written."
    When I install the Gateway program on a remote computer, then the symbol file and the Default.PRG file is downloaded.
    The troubble started when I installed IndraWorks.
    Any ideeas?
  • shooter - 2016-12-26
    as you well know, both are codesys products, so the driver is different, but the main program is the same.
    You can only have 1 codesys on your computer.
