I have an xyz 3axis system .
How do I connect an additional Q-axis to smc_interpolator so it is also controlled bij cnc (g code)?
The xyz you connect to the SMC_interpollator Pisetposition output with Trafo_gantry 3 function blok .
How do I connect/control the additional Q-axis ? ( to smc AxisConytrolByPos in CFC programming ?)
Didn"t find any info in online help about additional axis! (only how to use in g-code, but not how to connect to smc_interpolator ).
Did I miss relevant info/pages in online help?
tried some options and used Q-axis in G-code and found out that you have to use dA2 variable from smc _ Interpolator to connect to smc_ControlAxisByPosition
The axis controled in this way does not finish a task! .
If I use for example Q25 and next step Q0 it will start but not finish the first task, but right away steps to next line .
I can solve it with G4 T.. (time delay )
Do I something wrong here or does it work this way. Did I forget to connect a feedback?
The post is kinda old ... but I think it deserves to have a solution here that might be useful for someone.
If you look at the output [piSetPosition] of the [SMC_Interpolator] block you will see that it is a structure that contains the position of the axes (dX, dY, dZ ...), so just create a block to pull the values ​​out and then point them to each [SMC_ControlAxisByPos], such as SMC_TRAFO_ blocks does.
For example:
FUNCTION_BLOCKmyCNCPositionConverterVAR_INPUTEND_VARVAR_INPUT
  bExecute : BOOL;
  piSetPosition : SMC_POSINFO;END_VARVAR_OUTPUT
  iFrameNo : INT;
  dX : LREAL;
  dY : LREAL;
  dZ : LREAL;
  dA : LREAL;
  dB : LREAL;
  dC : LREAL;
  dP : LREAL;
  dQ : LREAL;
  dU : LREAL;
  dV : LREAL;
  dW : LREAL;END_VARIFbExecuteTHEN
  dX :=piSetPosition.dX;
  dY :=piSetPosition.dY;
  dZ :=piSetPosition.dZ;
  dA :=piSetPosition.dA;
  dB :=piSetPosition.dB;
  dC :=piSetPosition.dC;
  dP :=piSetPosition.dA1;
  dQ :=piSetPosition.dA2;
  dU :=piSetPosition.dA3;
  dV :=piSetPosition.dA4;
  dW :=piSetPosition.dA5;
  iFrameNo :=piSetPosition.iFrameNo;  END_IF
Another thing to note is that the auxiliary axes (A, B, C, P, Q, U, V and W) have unique speed and ramp settings, ie using the F20 command on one line of G code will specify the speed X, Y and Z axes only (with CNC in 3D mode). For example, to set the speed for the P axis, you have to use "FP20":
G01P100F20E30E-30>>Thatwon't work for P Axis!G01P100FP20EP30EP-30>>Thatworks!
Question
check the online help,
depending on what you Need uvw or a,d,c axis..
For example:
You will find more information here:
https://help.codesys.com/webapp/_sm_cnc_din66025_basics;product=codesys_softmotion;version=4.6.0.0
Also note that you cannot use the A, B, and C (Rotary) axes together with the U, V, and W (Linear) axes.
https://help.codesys.com/webapp/_sm_cnc_din66025_additional_axis;product=codesys_softmotion;version=4.6.0.0
The documentation really is a bit complicated, and this is based on the tests I did, maybe someone has another way of doing it or other opinion...
Thank you! This help me too.
