I am using Codesys V3.5.7 (EATON version) with web visualisation.
I have a rounded rectangle with gradient fill as a background.
On creating any meter from the measurement controls section as the foreground, the meter is placed at the back and only the pointer is visible in the foreground.
Is this a bug and is there any other way of doing this?
Many thanks.
I have faced this issue, but i usually ungroup them first.
i click on meter... go to properties of the element ----> background image; which shows <default>..... i clear this section and no image for this meter. I add other circluar image.</default>
then right click on the circular bmp and click on order ---> send to back.
then right click on meter and click on order -----> send to front.
then adjust the meter and circular image in such a way that their centre match...
Can somebody help with this please?
Many thanks.
Hi There,
