Change IP Address from CAA Runtime on PFC200
2016-10-28
2016-10-29
  • jessejamescox - 2016-10-28
    Hello, struggling with finding a way to change the target's IP address from within the PLC runtime. This is a feature that has always been available from WAGO on CoDeSys 2.3 and e!Cockpit Is there a TCP/IP config library or Linux command line block that will accomplish this?
    eschwellinger - 2016-10-29
    for me it works with adding the setting (add the Interface which you want to set)
    [SysSocket]
    Adapter.0.Name="ethX2"
    Adapter.0.EnableSetIpAndMask=1
    in /etc/CODESYSControl.cfg
    and set the IP by adding the 'Ethernet Connector' to your project and set 'Change Operation System setting' see screenshot
    IMG: setip.jpg
    CheckLicensePFC200.project [79.32 KiB]
