if you are connected for example by wifi (or and third party usb-to-ethernet adapter)... just use the ip and deploy the runtime
The scan does not work because the wifi interface has a different mac address... (this will be solved with 3.5SP11)
If you just use the knowm ip.... it will should work.
Thank you for your response. Weird thing is that I cannot find the device, but when I check installed packages on the graphical UI in my PI, the latest version shows.
I am now trying with another PC, and was able to find it that way.
Another question. How can I check if my license is still present on the rPI?
Seems that I have lost my license during numerous updates, I should have a back-up somewhere, but not sure where to look for it. Is there any way to receive a new license? I am still using the same rPi I originally used and have the original confirmation email with license code.
Hi all,
Trying to update my rPi with the latest image, but having no luck.
When I scan for a device, it says none is discovered. I am connected to SSH and can connect with VNC, but no luck with CodeSYS. Any pointers?
Thank you!
Hello Edwin,
just check it here in PLC settings
Thank you so much!
