ooops... this runtime was built for raspberry pi (-12, 0x00000BB8, 0xFFFFFFFB)
jan233321
2016-11-27
2023-08-17
  • jan233321 - 2016-11-27
    Hi all,
    I'm glad we have now a possibility to use our devices with Codesys - widely known and accepted platform even in our Raspberries.
    I'm trying to get a bit more from it and help trainees to understand what is latency and how it "works". For this I'm compiling my kernels for Rasp. by myself.
    Today I found a strange behavior - I'm playing with pretty new kernels (4. and codesys runtime always suddenly stops without any real error - and I found this ooops in log (please see the attachments).
    I believe my kernels are OK, basically this are the standard ones only with preempt and/or RT patches... but codesys realtime is somehow checking something and it found out it is not running on Raspberry (of course is wrong, it is running on raspberry).
    Here are some additional details
    cat uname
    Linux raspberrypi 4.8.10-v7+ #2 SMP PREEMPT Sun Nov 27 20:30:55 CET 2016 armv7l GNU/Linux
    Codesys runtime is 3.5.9.40
    Cpuinfo is in the attachment.
    Can I do something to get rid of this ooops?
    Thanks,
    Regards
    Jan.
    cpuinfo.txt [1.11 KiB]
    codesys.txt [21.06 KiB]
    eschwellinger - 2016-12-01
    not really sure what is mssing.
    you need to compare the kernel modules which are running.
    I would recommend to use emlid / naivio (search the forum) and use a precompiled rt_preemt kernel embedded in an ready to use Image.
  • jan233321 - 2016-12-01
    Hi Edwin,
    well, missing modules are not likely the case.
    If I build kernel 4.4.35 without hard RT and 4.8.10 also without hard RT then with 4.4.35 has runtime no problem at all and works fine. With 4.8.10 it detects something "wrong" and bails out with this message.
    Can you see from the code (-12, ....) what is wrong, the reason why to believe it is not running on raspberry?
    Please note - kernel 4.8 detect the raspberry CPU as BCM2835 (see the /proc/cpuinfo file pls.) and kernel 4.4 as BCM2709 (4.4. kernel is particularly wrong as 2709 is chip family name https://github.com/raspberrypi/linux/issues/22).
    Can you please double check it? I believe internal "protection" against non-raspberry use needs to be updated...
    Jan.
    we agree that this need to be fixed!
    This will be released with 3.5SP10 release on 15th december. (+x days for the Pi Release in the CODESYS Store)
    eschwellinger - 2016-12-18
    Hi Jan,
    this should work now with 3.5.10.0 release.
    Could you please check this?
  • jan233321 - 2017-03-06
    Hi Edwin,
    I can confirm, it works.
    Thanks,
    Jan.
  • jreitzig - 2021-12-07
    The error just popped up again... stuff was working fin till yesterday :-(
    Hardware : BCM2711
    Revision : c03114
    Serial : xxxxxxxxxxxx
    Model : Raspberry Pi 4 Model B Rev 1.4
    root@rasp4:~# uname -a
    Linux rasp4 5.10.83-v7l+ #1499 SMP Tue Dec 7 14:08:09 GMT 2021 armv7l GNU/Linux
    Any ideas ? Thx
    eschwellinger - 2021-12-07
    which runtime version are you using with the PI4?
  • jreitzig - 2021-12-08
    Hi. Just a fresh reinstall of the latest RPI OS. The CodeSys runtime is 4.2.0.0 logs. It seems the device error is gone, yet I still can no longer get the modbus tcp conncetion to work.
    Even though the logs seem to indicate that the slave (192.168.100.106) is the root of the issue, I can assure that not a single byte is crossing the wire in neither direction as I am checking via tcpdump/wireshark using display filters for mbtcp. It all worked flawlessly until 2 days ago and now I am getting the error "Connection aborted: socket_recv() failed!"
    Can somebody see from looking at the logs whats going on ?
    Hi. thanks for your replies....This was a "layer 8 problem". Still not knowing how I got in and out of this mess I am now back on track... Just two last questions (taking this thread totally off-topic:-( ):
    1) The icons for modbus do not turn green but are operational... any deeper meaning to this ?
    2.) If this is related to the demo license (for raspberry), do I also need an additional license for ModBus ? The logs let me assume this: Demo mode for Modbus/TCP Master started.
    Thank you
